Cisco SD-WAN requirements with EVE-NG
Lan_Ci
Hi all,
I have one question. My computer performances are 16 GB of RAM and intel Core i7. I want to build SD-WAN labs with eve-ng on it.
So is it enough to get hands on practice with this technologies ?
Thanks.
RAM is not enough. For normal, operations you should have at least 24G RAM for vManage. vSmart / vBond require 2/1 RAM. Per C8000V needs minimum 6-8 RAM. vEdge can work with 1G ram.
HTH,
I started my lab on the I7 + 32Gb RAM)) vManage + vSmart + vBond + 2 c8000v
