cisco sd-wan simulation
kingcarjh
i want study cisco sd-wan
cisco sd-wan simulation URL??? plz..
13 Replies 13
Francesco Molino
When you talk about sd-wan is it viptela or iwan?
Iwan can be done using Cisco virl (software with virtual routers).
Viptela, you need to deploy vm.
I'm not aware of demo url except dcloud.cisco.com
If you have access, there are multiple labs and you can play with different solutions. Both iwan and viptela are there.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
tahiali
for overall look and feel demo
http://sdwandemo.cisco.com
demo/demo
if you are a partner/client and have SA/VA you can spin up some cloud licences or use your existing hardware.
you can also check
https://dcloud-cms.cisco.com/demo_news/cisco-4d-sd-wan-viptela-v2
Seems that the link sdwandemo.cisco.com is broken
I believe it's not accessible from the outside of cisco. Please use dCloud, that's great resource for learning
https://sdwandemo.cisco.com:8443/
use this instead i just tested it outside cisco
Would anyone know the credentials for this online resource?
Thanks for any reply....
Not sure you can access it directly.
Go on this link and you’ll get access:
https://dcloud2-rtp.cisco.com/content/instantdemo/cisco-sd-wan-viptela-v1-instant-demo
Francesco
Thanks for reply unfortunatley that not work either. Nevermind ... too hard
What do you mean? It works perfectly fine, just checked it. Use "resources" tab to find PDF with explanation and credentials.
Thank you... I click on this below:
2019-01-21 20h54m56 Instant Demo Resources.pngand I indeed get a PDF.
On P1 under Requirements it says I need Cisco anyconnect. Fair enough.
I cannot find anywhere that telles me a dns name/port or ip address/port to connect to, or password for Cisco Anyconnect.
Am I missing something?
If you go back to the supplied URL and click on View see below:
the vManage GUI opens in a new tab.
What credentials woudl I need for that?
I dont see any credentials in the PDF.
The PDF I downloaded is attached so you can see what I am reading.
Thanks...
Please see page 4 carefully. There is credentials for vManage GUI. I think you don't need AnyConnect to connect, it's specified as "Optional". As far as I can see, demo vManage gui is published with external IP.
Bingo. I am in.
Greatly appreciate your persistent help!
Thanking you..... ekhabaro!!!
You’re welcome. Hope you’re enjoy demo.
