Cisco SD-WAN Static NAT
maverick0
Hi Guys
I need help to configure the Static NAT on the vEdge router to allows the external access to the internal servers. The vEdge has two Internet links from different service provider and DIA is enable by using Data Policy. In the Static NAT settings I've specified the NAT Pool Range Start and End values (I'm using two public IP address) and I've created the two Static NAT for each server. The device template has been deployed successfully into the vEdge. However, when I try to make some test from using the Static NAT from the Internet, I'm not getting answer from the servers. The application is running on the servers, just the Internet access is not working.
Please let me know if someone here already face this issue in the vEdge?
0 Replies 0
