Cisco SD-WAN vManager Reboot
RS19
Level 4
Level 4
This is regarding Cisco SD-WAN vManager reboot.
I want the right procedure how to reboot the vManager without any issue.
Give me reference link or the details how to reboot it.
Also let me know if the reboot is possible via GUI or via CLI ?
6 Replies 6
RS19
Level 4
Level 4
I understand there are 2 commands.
request nms all restart
reboot
 Which one is recommended. My understanding is that 1st command will not have any impact. 2nd command will have impact.
Correct me If I am wrong.
vManage failure does not impact data plane/control plane of the routers. Only you lose management/monitoring of the router from vManage point of view which is logical because vManage is down.
HTH,
Please refer to the below article (Sorry its in Japanese, but try to translate online)
SD-WAN: Troubleshoot GUI Related Issues in vManage - Cisco Community
Its mention with reboot command there will little interruption.
RS19
Level 4
Level 4
Any inputs or suggestions ?
Agree, if port-hop happens then all BFDs on the device will be impacted.
HTH,
Thanks.
Can you please help in explaining more on this ?
