Cisco SD-Wan vs dual ISP failover topologies with BGP
lcaruso
Level 6
Level 6
Hi, I am new to Cisco SD-Wan obviously and would like to know if it can replace a common wan topology solution for a site requiring dual ISPs either failover or load-balanced with a public ip range independent of the ISP routing to those addresses as is commonly done with eBGP. Thanks for your insights.
svemulap@cisco.com
Yes. Please check the SD-WAN Design Guide.
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html?dtid=osscdc000283#UseCases
Check the Use Cases Section for more information.
HTH.
svemulap@cisco.com
HTH.
