SD-WAN switchport feature unavailable for use in configuration group
Im working on understanding the configuration group and feature profile functionality in the newer versions of vManage. I have created a configuration group with the necessary feature profiles to replicate my current device and feature templates. However i am not able to create the switchport feature. The option is grayed out when i press Add feature and try to select it from the drop down menu (see picture below).
My user has all read and write privileges and i can add all other features except switchport. I have tried to add Service VPNs with SVIs, but the switchport feature stays grayed out.
The documentation for configuration groups and feature profiles makes no mention of requirements for the switchport feature. (https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/configuration-groups.html)
Anyone else experiencing this issue or know if i may be missing something?
EDIT: I am using version 20.9.2 for the controllers.
0 Replies 0
