Cisco SD-WAN with AWS Direct Connect
RS19
Level 4
Level 4
I am planning to connect to my AWS VPC via Direct connect & using Cisco SD-WAN
Is there any configuration, design document from Cisco to use SD-WAN to connect to AWS Direct connect ?
svemulap@cisco.com
hi RS19 -
Yes. We have it as part of SDCI solution where you can do S2S or S2C using (megaport) interconnect.
All done through the vManage automation. Support is there as part of 20.5 / 17.5 release.
# https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/cloudonramp/ios-xe-17/cloud-onramp-book-xe/m-cloud-onramp-sdci.html
My SD-WAN software version running is 16.12 , not 20.5/17.5
In this case is there any reference materials for configuring the Cisco SD-WAN  to AWS
