Cisco SDWAN Control Connection: TLS vs DTLS
Hi All.
I have Cisco SDWAN running well using Control Connection on DTLS. For some reason, our customer asked to change the control connection to TLS. Can someone please share document related to pro-cons for control connection using dtls / tls on Cisco SDWAN? Thank you.
You can try Chapter 2 of this document where it talks about DTLS/TLS:
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/security/vedge/security-book.pdf
-David
with vBond it is always DTLS. With vSmart/vManage it can be TLS also and it is recommended as below (from Cisco SD-WAN CVD):
"TLS is recommended since it uses TCP, which uses acknowledgments for greater reliability. TCP is also connection-oriented, so firewalls can maintain the state of the connections and allow return traffic without explicitly having to allow the traffic."
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html
HTH,
HTH,
