vSmart connection does not show up
interfacedy
Hi Please see the below. The device below is one of the vEdges. but why this one does not show vSmart connection? Thank you
5 Replies 5
it can be lots of possible reason..
Do you have control connections between vsmart and vbond/vmanage? And check for an issue with "show control connection-history" on vedge
HTH,
HTH,
interfacedy
Thank you for your reply!
What command can have control connections between vsmart and vbond/vmanage?
show control connections on vSmart/vManage
show orchestrator connections on vBond
Below guide is very helpful for troubleshooting of control connections:
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/214509-troubleshoot-control-connections.html
HTH,
HTH,
interfacedy
Thank you very much for your reply!
In vBond, "show control connection / show orchestrator connection" show nothing. certificates installed successfully. why it cannot show any connection?
Use show orchestrator connection-history to understand the error in communications.
You can use show control connection-history from vmanage/vsmart as well.
HTH,
