Cisco SDWAN Lab in EVE NG - vEdges can't ping next hop
Running Images 18.4.5 of SDWAN, on latest version of EVE-NG. Have this issue where after the lab sits idle powered on for overnight, the vEdges cannot ping next hop or anything but themselves.
I did notice that the static default route was dropping from the table and it took a reboot to fix that until I found this.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp46172
So after that the static default route is injected again but vEdge cannot ping next hop IP.
vEdge-01# show run
system
host-name vEdge-01
system-ip 10.12.0.1
site-id 12
admin-tech-on-failure
no route-consistency-check
organization-name LAB
no track-default-gateway
clock timezone America/Chicago
vbond 223.1.1.11
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
logging
disk
enable
ntp
server 223.1.1.13
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
vpn 0
router
bgp 65012
address-family ipv4-unicast
network 172.31.11.0/24
neighbor 172.31.11.1
no shutdown
remote-as 100
interface ge0/0
ip address 192.1.1.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
color public-internet restrict
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
allow-service https
no shutdown
interface ge0/1
ip address 172.31.11.2/24
tunnel-interface
encapsulation ipsec
color mpls restrict
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service https
no shutdown
ip route 0.0.0.0/0 192.1.1.1
vpn 512
interface eth0
ip dhcp-client
no shutdown
vEdge-01#
show ip route
Codes Proto-sub-type:
IA -> ospf-intra-area, IE -> ospf-inter-area,
E1 -> ospf-external1, E2 -> ospf-external2,
N1 -> ospf-nssa-external1, N2 -> ospf-nssa-external2,
e -> bgp-external, i -> bgp-internal
Codes Status flags:
F -> fib, S -> selected, I -> inactive,
B -> blackhole, R -> recursive
PROTOCOL NEXTHOP NEXTHOP NEXTHOP
VPN PREFIX PROTOCOL SUB TYPE IF NAME ADDR VPN TLOC IP COLOR ENCAP STATUS
0 0.0.0.0/0 static - ge0/0 192.1.1.1 - - - - F,S
0 10.12.0.1/32 connected - system - - - - - F,S
0 172.31.11.0/24 connected - ge0/1 - - - - - F,S
0 192.1.1.0/24 connected - ge0/0 - - - - - F,S
vEdge-01# ping vpn 0 192.1.1.1
Ping in VPN 0
PING 192.1.1.1 (192.1.1.1) 56(84) bytes of data.
From 192.1.1.2 icmp_seq=1 Destination Host Unreachable
From 192.1.1.2 icmp_seq=2 Destination Host Unreachable
From 192.1.1.2 icmp_seq=3 Destination Host Unreachable
From 192.1.1.2 icmp_seq=4 Destination Host Unreachable
From 192.1.1.2 icmp_seq=5 Destination Host Unreachable
^C
--- 192.1.1.1 ping statistics ---
6 packets transmitted, 0 received, +5 errors, 100% packet loss, time 4999ms
pipe 4
vEdge-01# show arp vpn 0
IF IDLE
VPN NAME IP MAC STATE TIMER UPTIME
0 ge0/0 192.1.1.2 50:00:00:05:00:01 static - 1:16:42:49
0 ge0/1 172.31.11.2 50:00:00:05:00:02 static - 1:16:42:49
vEdge-01#
INET#ping 192.1.1.1
Sending 5, 100-byte ICMP Echos to 192.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
INET#ping 192.1.1.2
Sending 5, 100-byte ICMP Echos to 192.1.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
INET#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 101.0.0.1 - 5000.000c.0008 ARPA GigabitEthernet0/8
Internet 172.16.31.1 101 78bc.1af2.099f ARPA GigabitEthernet0/9
Internet 172.16.31.73 - 5000.000c.0009 ARPA GigabitEthernet0/9
Internet 172.31.111.1 - 5000.000c.0006 ARPA GigabitEthernet0/6.172
Internet 192.1.1.1 - 5000.000c.0001 ARPA GigabitEthernet0/1
Internet 192.1.1.2 0 5000.0005.0001 ARPA GigabitEthernet0/1
Internet 192.1.2.1 - 5000.000c.0002 ARPA GigabitEthernet0/2
Internet 192.1.2.2 0 5000.0006.0001 ARPA GigabitEthernet0/2
Internet 192.1.3.1 - 5000.000c.0003 ARPA GigabitEthernet0/3
Internet 192.1.3.2 0 5000.0007.0001 ARPA GigabitEthernet0/3
Internet 192.1.4.1 - 5000.000c.0004 ARPA GigabitEthernet0/4
Internet 192.1.4.2 0 5000.0008.0001 ARPA GigabitEthernet0/4
Internet 192.1.100.1 - 5000.000c.0000 ARPA GigabitEthernet0/0
Internet 192.1.100.2 193 5000.0003.0000 ARPA GigabitEthernet0/0
Internet 192.1.101.1 - 5000.000c.0007 ARPA GigabitEthernet0/7
Internet 192.1.111.1 - 5000.000c.0006 ARPA GigabitEthernet0/6.192
INET# show run int gi0/1
Building configuration...
Current configuration : 144 bytes
interface GigabitEthernet0/1
ip address 192.1.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no mop enabled
no mop sysid
end
INET#
So from the INET router directly connected I cannot ping the vEdge either, but it looks to have an arp entry. The vEdge does not seem to have an arp entry.
Anyone experience this before?
So there must be an underlying issue with this version of SDWAN images. Even with configuring vedges to not track gateway using command "no track-default-gateway" under system, at some point vEdges lose connectivity to vManage within EVE-NG. The fix is I just have to reboot all the vEdges when this happens then it lasts for a day or so.
