Cisco SDWAN
abdul.qadir5001
Can we use same IP Address for Sysem IP and VPN 0 of a vBond and vSmart
5 Replies 5
No you can not
MHM
Dear Can you please tell me what is the reason for it?
System IP is like router ID in ospf/eigrp/bgp
You can not have same router ID in your network' even if this system IP not need to know by underlying but it identify the device.
Use same system ID in two device make issue in edge and vmanage to connect to these device.
Avoid that
MHM
balaji.bandi
Always suggest to look at the deployment guide and guide lines :
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/SD-WAN-End-to-End-Deployment-Guide.pdf
BB
Control connections between devices with the same systemIP are not established.
HTH,
