Communication between SD-WAN components
Hello;
I want to know the chronological order of communication between sd-wan components (vbond-vmanage-vsmart-vedge) and all the informations exchanged between them.
If possible in some simplified image or graphic.
Thank you.
5 Replies 5
Hello ;
I want to know what they send exactly in the dtls session in a chronological order
Thank you.
yes that document explains all the details
BB
It all start with cEdge joing vBound by resolving vBond DNS name somewhere on the internet or inside you network.
vBound will tell cEdge about the others elements like vManage and vSmart.
On the page bellow you have exactly all the information you need.
https://www.networkacademy.io/ccie-enterprise/sdwan/how-cisco-sd-wan-works
Hello ;
I already read the website by i still have the confusion.
Thank you
