Configuring an IPsec tunnel on a Catalyst 8200l series
kyle311
We have a client who has a Catalyst 8200L series that they are looking to setup an ipsec tunnel to connect to  the Verizon cloud.  it looks like the IPsec commands are not available.
Are they missing a license?
dijix1990
Sh ver and sh lic usage
8 Replies 8
check this post.
read Cisco employ reply
MHM
sorry there was not attachment
anyway the issue is solved
MHM
which commands exactly ? Share "show version". Normally , IPSec is supported even with network essentials license tier.
HTH,
dijix1990
kyle311
Yep, it was the licensing.  Thanks all for the guidance!
kyle311
now i guess the next question is, what license is required to be purchased?
kyle311
I am going to guess C8000-HSEC?
yeah, it is, if you want to encrypt above then 250mbps
