CSR1000V- invalid "system" command
R Manjunatha
Level 3
Level 3
I could not able to find the command "system" in the CSR 1000V router for SD-Wan system configuration.
please do the needful
Router# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#system
% Invalid input detected at '^' marker.
Router(config)#
Router(config)#do sh ver
Cisco IOS XE Software, Version 03.17.04.S - Standard Support Release
Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.6(1)S4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 24-Jul-17 17:49 by mcpre
Over weekend i had access to my Lab :
here is my setup PNET Lab i am using
I have downloaded the image name - csr1000v-ucmk9.16.12.1b-serial.qcow2 ( google can provide where to download) since you do not have access to Cisco ( for Lab i believe its ok for testing)
it boots as expected :
system it works :
Hope this information help you.
BB
15 Replies 15
balaji.bandi
Where are you trying this Image, esxi ? or any other simulator.
You need SD-WAN Image,
https://www.cisco.com/c/en/us/support/routers/csr-1000v-series-ios-xe-sd-wan/model.html#~tab-downloads
BB
Pnetlab...I have  downloaded this one of the links which they simulated
yes it works as expected.
BB
no, I tried a couple of times attached image is getting invalid command if I tried the "system" configuration.
this image does not even ask for the user name and password initial boot.
Once boot post show version. ( did you get the image from cisco  site or downloaded from google.)
BB
downloaded from google...since I don't have a cisco partner account to download the images.
when you boot with this image, what is show version show ( google images may be renamed version) but still old images.
BB
I have attached the initial boot device show version details for your reference
this is definitely not SD-WAN image.
First of all, traditional "conf t" should not work in SD-WAN image and there is no SD-WAN image for 15.x releases.
You either need to download 16.x version from IOS XE SD-WAN series OR 17.2.x and later from IOS XE series.
Note that, after 17.2 (and including 17.2), there is only one universal image which can be used for traditional router deployment or for
SD-WAN. You need to enable controller mode, if you want to run it in SD-WAN.
https://software.cisco.com/download/home/286323714/type/286321980/release/16.12.5
https://software.cisco.com/download/home/286323714/type/282046477/release/Amsterdam-17.3.4a
HTH,
HTH,
yes....but I don't have a service contract with cisco
Service Contract Required
To Download this software, you must have a valid service contract associated to your Cisco.com profile.
If you do not have a service contract you can get one through:
  • Your Cisco Account Team if you have a direct purchase agreement with Cisco
  • Your Cisco Partner or Reseller
You have 2 options
if you have any cisco partner who help you to get image,
google or ask forums (not cisco) other emulator/simulator forums, people may share with you.
BB
system it works :
BB
yes...I got the same as per your instruction and now it's working on some other version of the image which I downloaded.
Thanks for the update
To be honest i dont know, since internet images are floating different some works and some not. but glad it working that is important to move to next level to do our labs
BB
