CUBE in SD-WAN?
Roman Rodichev
Level 7
Level 7
Does anyone know if CUBE is supported in SD-WAN? Everything I find references SIP-to-Analog only and some 2020 document saying other functionality is on the roadmap. Is it actually possible to configure SIP-to-SIP dial-peers, where:
1. CUCM is in VPN 1 and SBC is in VPN 0
2. CUCM is in VPN 1 and SBC is in VPN 1
I know this is possible in autonomous mode as dial-peers are vrf-enabled, but what about SD-WAN?
Thank you!
Roman Rodichev
Level 7
Level 7
In case anyone has the same question in 2021, the answer is that CUBE support is coming in version 20.7 scheduled for December 2021
@Roman Rodichev  Thank you for the information!
Could you share where this information is located, please?
Regards.
