dCloud SD-WAN 20.9 Custom Topologies import/upload topology.
aasselin1
I created topology with SD-WAN 20.9 Custom Topologies with version 20.9.1 and exported to tar.gz file
When I import/upload the topology, I can modify any device and/or add new link.
It looks like it is in read access only?
In addition, there are always issues to deploy saved/import previous topology.
I would like to create topology and use during time of my sdwan training.
Thanks in advance for your reply.
I think you should check with Support, it's strange, I've been using dcloud for almost 6 months to prepare for the exam as well and I've never really had a problem, for now... I've imported and exported and I haven't had any problems, maybe sometimes during initialization where the controllers do not connect to the internet and in these cases it is solved by changing the version to a minor one.
I recommend that you talk to dcloud Support, they usually respond very quickly, on the other hand if you plan to prepare for the exam I do not advise you to use dcloud custom topology only, some functions are limited, I have not yet been able to upload a bootstrap file to a cEdge or vEdge for example
