Problem when attaching a template with changes to a cEdge
I'm having problems with trying to update the template to a cEdge. I need to add a couple of commands to the configuration.
When apply the template from vManage with the changes it goes to Schedule as if the router were offiline but when I connect to it remotely I can see that it is connected to the Vmanage, it has the control connections up.
If I try to put in CLI mode from Vmanage I get unable to connect to vmanage-admin@IP:830
If I try to add the commands in the router directly it says Aborted "system is vmanaged"
Any idea how to sync both or how to solve the issue?
Regards and thanks
what do you see in "show control connections" (on router add sdwan keyword after show) for vmanage and router?
830 is netconf port, it is not mandatory to have it opened. You have DTLS/TLS channel for control communication. So, try to troubleshoot via DTLS/TLS control traffic.
HTH,
