DIA
RS19
Level 4
Level 4
This is regarding DIA access for SAAS applications from the below URL.
https://www.cisco.com/c/en/us/solutions/collateral/cloud/guide-c07-741223.html
As prerequisite they have mentioned the below.
Query:
- Its mentioned that 1st couple of packets of a flow need to take the traditional routing path.
What does this mean ?
- Then its mentioned that subsequent flows can be directed to the internet by DIA path.
 My understanding is that both will follow the default gateway path via vEdge ?
ekhabaro
Hi! I hope Design Guide will help you to understand how it works: https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/CVD-SD-WAN-Cloud-onRamp-for-SaaS-Deployment-Guide-2018JUL.pdf
See section "Cloud onRamp for SaaS feature overview" and then go to "Traffic forwarding" and "Prerequisites"
Thanks.
My understanding is that "Cloud onRamp for SaaS feature overview" at present is not available in Cisco ISO XE .
Let me know if my understanding is right.
