Disable cdp from templates
Is is possible to disable cdp from WAN (ethernet) interfaces from template?
I didn't find the option.
Regards and thanks
use CLI-add on template and see it affects or not. In qualified commands, I found "cdp enable" ,thus "no cdp enable" should also work under respective port.
HTH,
