down-in-gr SATE when show omp peer
jianli
Hi Team,
In customer production and lab network, we both have down-in-gr wrong state issue when you show omp peer.
When you doing vEdge upgrade and after reboot, you may found on the vSmart the omp peer state changed to "down-in-gr". But if you clear omp peer it will turn to up state.I think it should automatically no need manually clear it.
The graceful restart timer on the vSmart is default 12 hours, and on the vEdge is 48 hours.
Do you have any idea for it?
U-lab-DC1-VSM01# show omp peers
R -> routes received
I -> routes installed
S -> routes sent
DOMAIN OVERLAY SITE
PEER TYPE ID ID ID STATE UPTIME R/I/S
10.0.128.5 vsmart 1 1 1002 up 2:22:30:10 726/0/882
10.0.128.7 vedge 1 1 1001 up 2:22:30:11 184/0/219
10.0.128.8 vedge 1 1 1001 up 2:22:30:06 184/0/219
10.0.128.9 vedge 1 1 1003 up 0:07:02:41 196/0/219
10.0.128.10 vedge 1 1 1003 down-in-gr 128/0/0
10.0.128.11 vedge 1 1 101 up 2:22:29:49 36/0/951
10.0.128.12 vedge 1 1 101 down-in-gr 64/0/0
10.0.128.13 vedge 1 1 201 up 2:22:29:40 34/0/953
10.0.128.14 vedge 1 1 201 up 2:22:29:46 32/0/955
10.0.128.17 vedge 1 1 401 up 0:06:58:46 24/0/971
10.0.128.39 vsmart 1 1 1000 up 2:22:30:11 545/0/882
10.0.128.40 vsmart 1 1 1002 up 2:22:30:11 291/0/882
10.0.128.44 vedge 1 1 801 up 2:22:30:00 4/0/989
rajivrajan1
Level 3
Level 3
end of rib missing from vs - did you find the solution?
