Dual ISP failover on vEdge
btjtaylor
Hi all
I'm building an SDWAN lab and one of my scenarios I want to test is dual ISP failover at a branch location
I am confused about how you set up the default routes. I want the default route to switch to the second ISP connection if the primary ISP is broken (in the past I did this using IP SLA)
The tunnel part actually works correctly without any extra config but the internet breakout doesn't work
I created a tracker object as per Systems and Interfaces Configuration Guide, Cisco SD-WAN Release 20.x - Track Static Routes for Service VPNs [Cisco SD-WAN] - Cisco but when I try to apply this to VPN0 as per my screenshot below I get the error "Static route tracker cannot be configured for VPN 0":
Is there any recommended way to do this?
Thanks in advance
configure 2 different trackers and apply them to different interfaces (per tracker per interface). This is "must" option per "DIA Deployment Guide".
Page 24-26 describes router with 2 internet (+NAT) channels
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/sdwan-dia-deploy-2020aug.pdf
HTH,
HTH,
you may use interface tracker. It is created in system template, but applied to interface in interface template - advanced options.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/dia-tracker-ios-xe.html
HTH,
HTH,
I got the route tracking working but the NAT doesn't work once failed over
Here's my config:
S4-VE1# show run
system
 host-name               S4-VE1
 system-ip               9.9.9.9
 site-id                 4
 admin-tech-on-failure
 no route-consistency-check
 no vrrp-advt-with-phymac
 sp-organization-name    BT_SDWAN_LAB
 tracker tracker1
  endpoint-dns-name www.bbc.co.uk
  threshold         100
  interval          10
 clock timezone Europe/London
 vbond 203.0.113.13
 aaa
  auth-order local radius tacacs
  usergroup basic
   task system read write
   task interface read write
  usergroup netadmin
  usergroup operator
   task system read
   task interface read
   task policy read
   task routing read
   task security read
  user admin
   password xxx
  user ciscotacro
   description CiscoTACReadOnly
   group       operator
   status      enabled
  user ciscotacrw
   description CiscoTACReadWrite
   group       netadmin
   status      enabled
 logging
  disk
   enable
 ntp
  parent
   no enable
   stratum 5
  exit
omp
 no shutdown
 graceful-restart
 advertise connected
 advertise static
security
 ipsec
  authentication-type sha1-hmac ah-sha1-hmac
banner
 login "Test Banner"
 motd  "Test MOTD"
vpn 0
 dns 8.8.4.4 secondary
 dns 8.8.8.8 primary
 interface ge0/0
  ip address 100.64.4.2/29
  nat
  tracker  tracker1
  tunnel-interface
   encapsulation ipsec
   color public-internet
   allow-service all
   no allow-service bgp
   allow-service dhcp
   allow-service dns
   allow-service icmp
   allow-service sshd
   allow-service netconf
   no allow-service ntp
   no allow-service ospf
   no allow-service stun
   allow-service https
  no shutdown
 interface ge0/1
  ip address 100.64.4.10/29
  nat
  tracker  tracker1
  tunnel-interface
   encapsulation ipsec
   color biz-internet
   allow-service all
   allow-service dhcp
   allow-service dns
   allow-service icmp
   allow-service sshd
   allow-service https
  no shutdown
 ip route 0.0.0.0/0 100.64.4.1
 ip route 0.0.0.0/0 100.64.4.9
vpn 1
 interface ge0/2
  ip address 10.4.1.1/24
  no shutdown
 ip route 0.0.0.0/0 vpn 0
vpn 512
 name OOB_MGMT
 interface eth0
  description OOB_MGMT
  ip address 172.17.12.9/16
  no shutdown
 ip route 0.0.0.0/0 172.17.0.1
S4-VE1#
When both connections are up:
S4-VE1# show int ge0/0
interface vpn 0 interface ge0/0 af-type ipv4
ip-address 100.64.4.2/29
if-admin-status Up
if-oper-status Up
if-tracker-status Up
encap-type null
port-type transport
mtu 1500
hwaddr 00:50:56:83:74:0b
speed-mbps 1000
duplex full
tcp-mss-adjust 1416
uptime 0:01:25:40
rx-packets 67441
tx-packets 81015
S4-VE1# show ip route nat
Codes Proto-sub-type:
IA -> ospf-intra-area, IE -> ospf-inter-area,
E1 -> ospf-external1, E2 -> ospf-external2,
N1 -> ospf-nssa-external1, N2 -> ospf-nssa-external2,
e -> bgp-external, i -> bgp-internal
Codes Status flags:
F -> fib, S -> selected, I -> inactive,
B -> blackhole, R -> recursive, L -> import
PROTOCOL NEXTHOP NEXTHOP NEXTHOP
VPN PREFIX PROTOCOL SUB TYPE IF NAME ADDR VPN TLOC IP COLOR ENCAP STATUS
1 0.0.0.0/0 nat - ge0/0 - 0 - - - F,S
65528 0.0.0.0/0 nat - ge0/0 - 0 - - - F,S
512 172.17.0.0/16 connected - eth0 - - - - - F,S
65528 192.168.0.0/24 connected - loopback65528- - - - - F,S
Once primary internet connection is down .. no NAT any more even though its enabled on the interface...
if-admin-status Up
if-oper-status Up
if-tracker-status Down
encap-type null
port-type transport
mtu 1500
speed-mbps 1000
duplex full
tcp-mss-adjust 1416
uptime 0:01:27:49
rx-packets 68576
tx-packets 83064
S4-VE1#
HTH,
HTH,
Thanks for that - I missed that part in the guide!
Weirdly enough, before your reply, I upgraded the vEdge to 20.5.1 and my setup using the same tracker actually started working without any changes... but I will use 2 different trackers in future if I have further problems as it's best to meet the recommendations from Cisco.
NAT routes now look like what i'd expect:
Codes Status flags:
1      0.0.0.0/0           nat              -         ge0/1       -                0        -                -                -      F,S
65528  0.0.0.0/0           nat              -         ge0/1       -                0        -                -                -      F,S
65530  0.0.0.0/0           nat              -         ge0/1       -                0        -                -                -      F,S
65530  0.0.0.0/0           nat              -         ge0/0       -                0        -                -                -      F,S
