Enable Data Stream in Vmanage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-14-2023 12:35 AM
we need to enable data stream in Vmanage for Packet capture. As per recommendation we need to configure either of below one:
Management IP address and VPN 512
Transport IP address and VPN 0
can anyone please confirm whether we should configure MGMT IP Address or Transport IP address. Also currently these IP are not pingable from CEDGE device. so would we be still able to capture traffic or we need to enable ping first to capture traffic via Vmanage.
- Labels:
SD-WAN vManage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2023 11:43 PM
The simplest way to configure this is to use the system option. This option is also the best option if you have a vManage cluster. With this option you don't need ping enabled, the captured traffic will be sent on the control tunnel to vManage from the edge device.
