use of weight command
knaik99
husseino
Weight is configured under tunnel interface. It is used for load-sharing. Default value is one. If you configure circuit T1 With Weight 10, and T2 is with default weight=1. For a specific destination, if both tunnels are used, ECMP is used by default, with weight 10 packets will got to T1 and one packet goes to T2 following the associated weight value.
