enabling NAT on WAN interface - interfere with OSPF - help please
shlomim
I'm running SD-WAN LAB 20.9.3.1.
I have 2 Viptela vEdge routers that are connected via OSPF on WAN interfaces.
when I enable NAT on the WAN interface , despite there is no NAT configuration other than the nat on the interface - the vEdge router interfere with the OSPF packets.
I've tried to allow specifically OSPF on the tunnel interface - but it did not help:
when I disable NAT - the OSPF goes back again and after a while dies again.
here is the show run:
vEdge2# show run
system
host-name vEdge2
system-ip 172.17.1.222
site-id 1
admin-tech-on-failure
no route-consistency-check
no vrrp-advt-with-phymac
sp-organization-name or2.sys.cisco
console-baud-rate 9600
vbond 150.1.1.103
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$5adfbd0f5fea9400$roQOvt.AyTiHpG.OvQEe1gISHLudwc/qVD92iX4KMoZthgVx64EmRUzos4w5ST6fMvWVBxsHGGwtBfnGgc/W21
ciscotacro-user true
ciscotacrw-user true
logging
disk
enable
ntp
parent
no enable
stratum 5
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
vpn 0
router
ospf
router-id 172.17.1.222
auto-cost reference-bandwidth 10000
timers spf 200 1000 10000
area 0
interface ge0/0
network point-to-point
exit
interface ge0/1
exit
exit
interface ge0/0
ip address 150.11.2.0/31
nat
tunnel-interface
encapsulation ipsec
color custom1
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
allow-service ospf
no allow-service stun
allow-service https
no shutdown
interface ge0/1
ip address 150.22.2.0/31
nat
tunnel-interface
encapsulation ipsec
color custom2
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service ospf
allow-service https
no shutdown
interface ge0/2
no shutdown
vpn 1
router
ospf
redistribute omp
area 67372036
interface ge0/2.10
exit
exit
bgp 12345
best-path
as-path multipath-relax
address-family ipv4-unicast
maximum-paths paths 4
neighbor 10.9.9.9
no shutdown
remote-as 999
interface ge0/2.10
ip address 10.10.10.2/24
mtu 1496
no shutdown
interface ge0/2.999
ip address 10.9.9.2/24
mtu 1496
no shutdown
omp
advertise bgp
advertise ospf external
advertise connected
vpn 512
name "Management VPN"
interface eth0
shutdown
here is the show ospf neighbors
vEdge2# show ospf neighbor
DBsmL -> Database Summary List
RqstL -> Link State Request List
RXmtl -> Link State Retransmission List
SOURCE DEAD
VPN IP ADDRESS INTERFACE ROUTER ID STATE PRIORITY TIMER DBsmL RqstL RXmtL
0 150.11.2.1 ge0/0 150.255.1.1 exstart 1 34 0 0 0
0 150.22.2.1 ge0/1 150.255.1.2 exstart 1 34 0 0 0
when I disable nat on the interfaces - OSPF works perfectly.
for testing - I've allowed OSPF service on 1 interface and on the other not - to verify if it works.
it does not.
any suggestions ?
balaji.bandi
why do you need NAT ?
check NAT config :
https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/220311-configure-service-side-static-nat-on-a-c.html
enable debug and check.
BB
thank you for your help !
the issue I'm facing is with vEdge Cloud 20.9.3 - the configuration guide you've referred me to is IOS XE so I'm not sure if I'm on the right track.
anyways - I need NAT for DIA, since I do the DIA with Data Policy - there isn't any NAT configuration, only NAT on the interface.
any suggestions for debug I should do ? when I check show policy service-path on the source IP of the neighbor with destination IP of 224.0.0.5 - it shows me that it is being blackholed.
