Error with dual DHCP helper on SDWAN template
kay.kang
We had setting with dual DHCP helper addresses on device template.
Recently, I made some change on the device template via [Configuration]-[Devices]-[Change Device Values], but the Change wasn't completed because of dual DHCP helper address.
It was successfully processed when I pull out one of helper addresses and left only one at the field.
Why does this happen?
And how can I resolve thos?
You should be able to add up to 4 ip helper address. So, the problem was not related to the number of helper. Make sure you did not use incorrect syntax.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge/systems-interfaces-book/configure-interfaces.html
Hi Flavio,
Just found out that our vmanage version has the bug relating to dual helper address.
It's needes to upgrade to fix it.
Thank you for your comments.
