10-20-2021 07:49 PM
HI guys
I have a SD-WAN Lab as bellow:
Now the tunel MPLS is down between 2 sites. Although It was up before. Can someone help me to troubleshoot:
At DC I don't have vEdge, so I consider DC as a LAN of SITE2
SITE 2 don't have directly MPLS line, but It can connect to MPLS hubs via DC
That 's why I have 2 connections between R9 and vEdge2:
10.100.12.0/24 for LANs connections
10.200.12.0/24 for vEdge2 MPLS connection
MPLS network doesn't have connection to orchestrator network. At the beginning I use command "no control-connections" on both edges:
vEdge1:
interface ge0/1
ip address 10.113.0.11/24
tunnel-interface
encapsulation ipsec
color mpls
vEdge2:
interface ge0/1
ip address 10.200.12.12/24
tunnel-interface
encapsulation ipsec
color mpls
vEdge2# ping vpn 0 10.113.0.11 source 10.200.12.12
Ping in VPN 0 PING 10.113.0.11 (10.113.0.11) from 10.200.12.12 : 56(84) bytes of data. 64 bytes
from 10.113.0.11: icmp_seq=1 ttl=62 time=49.8 ms 64 bytes
from 10.113.0.11: icmp_seq=2 ttl=62 time=48.6 ms 64 bytes
from 10.113.0.11: icmp_seq=3 ttl=62 time=41.3 ms
I can ping via MPLS connections but it is down now:
vEdge1# show ip routes
Codes Proto-sub-type:
IA -> ospf-intra-area, IE -> ospf-inter-area,
E1 -> ospf-external1, E2 -> ospf-external2,
N1 -> ospf-nssa-external1, N2 -> ospf-nssa-external2,
e -> bgp-external, i -> bgp-internal
Codes Status flags:
F -> fib, S -> selected, I -> inactive,
B -> blackhole, R -> recursive
PROTOCOL NEXTHOP NEXTHOP NEXTHOP
VPN PREFIX PROTOCOL SUB TYPE IF NAME ADDR VPN TLOC IP COLOR ENCAP STATUS
0 0.0.0.0/0 static - ge0/0 20.20.21.10 - - - - F,S
0 10.100.1.0/24 static - ge0/1 10.113.0.1 - - - - F,S
0 10.113.0.0/24 connected - ge0/1 - - - - - F,S
0 10.200.12.0/24 static - ge0/1 10.113.0.1 - - - - F,S
0 11.11.11.11/32 connected - system - - - - - F,S
0 20.20.21.0/24 connected - ge0/0 - - - - - F,S
11 10.100.5.0/24 omp - - - - 12.12.12.12 biz-internet ipsec F,S
11 10.100.12.0/24 omp - - - - 12.12.12.12 biz-internet ipsec F,S
11 10.115.0.0/24 omp - - - - 12.12.12.12 biz-internet ipsec F,S
11 10.226.0.0/24 connected - ge0/2 - - - - - F,S
Solved! Go to Solution.
10-21-2021 07:50 AM
Understood....Based on outputs, MPLS interfaces are not considered valid TLOC even in local router itself.
So, vSmart doesnt see them and of course doesnt advertise to other routers.
"no control connections" is deprecated command, try to use " max-control-connections 0" so without vsmart-controller connectivity interface will be valid TLOC.
10-21-2021 06:24 AM
HI,
give outputs from both routers:
show bfd session
sh omp tlocs
sh omp tloc-paths
and from vsmart:
sh omp tlocs
sh omp tloc-paths
HTH,
10-21-2021 07:36 AM
Hi Kanan Huseynli , I send you all output:
vEdge1# show omp tloc-paths
tloc-paths entries 11.11.11.11 biz-internet ipsec
tloc-paths entries 12.12.12.12 biz-internet ipsec
vEdge2# show omp tloc-paths
vSmart# show omp tloc-paths
10-21-2021 07:50 AM
10-21-2021 08:26 PM
Oh my god, It really work now, tks you so much. It s a magic......
vEdge2# show ip routes
Codes Status flags:
0 0.0.0.0/0 static - ge0/0 20.20.22.10 - - - - F,S
0 10.113.0.0/24 static - ge0/1 10.200.12.1 - - - - F,S
0 10.200.12.0/24 connected - ge0/1 - - - - - F,S
0 12.12.12.12/32 connected - system - - - - - F,S
0 20.20.22.0/24 connected - ge0/0 - - - - - F,S
11 10.100.5.0/24 static - ge0/3 10.100.12.1 - - - - F,S
11 10.100.12.0/24 connected - ge0/3 - - - - - F,S
11 10.115.0.0/24 connected - ge0/2 - - - - - F,S
11 10.226.0.0/24 omp - - - - 11.11.11.11 mpls ipsec F,S
11 10.226.0.0/24 omp - - - - 11.11.11.11 biz-internet ipsec F,S
