I can not access GUI after the configuration of Vmanage. Help
Joel Mfunga
Hi, help please, i have configure Vmanage but i can not access GUI, i have enter this address https://192.168.140.135:8443
I have create the second disk but i dont know what's going on...
6 Replies 6
shambhu.kumar
Are you using default user name password? Please create new password and login through GUI using new password.
Shambhu Kumar
Yes, this is the defaut one, let me try and get back to you
Booting is taking more time. Since Vmanage was 1 hours ago I don't know if this behavior is normal. I am using the version 18.4
18.4 will not take much time for boot. What is allocation of RAM?
4 GB, if I upgrade it to 16GB the boot is not taking place .
