08-13-2024 04:20 PM
Hi everyone, i have thow problemes
1. I can not see the storage added
2. Vmanage runs and after 5 sec shutdown.
Please help me or guide me.
08-14-2024 01:20 AM
Can you see the file in your appliance folder if you run the following?
ls -ahl /opt/unetlab/addons/qemu/vtmgmt-20.7.1
It could be an issue with permissions. Run the following command to see if it makes a difference
/opt/unetlab/wrappers/unl_wrapper -a fixpermissions
You should also make sure to wipe the node after making changes to the appliance folder for the changes to take effect in your lab.
08-14-2024 03:19 AM
I have done what you asked me but Vmanage can not run
08-14-2024 06:46 AM - edited 08-14-2024 06:48 AM
Hello Joel,
Please delete it and re-create using below CLI
1- mkdir /opt/unetlab/addons/qemu/vtmgmt-20.7.1
2- Copy file into folder using winzip/filezila
3- cd /opt/unetlab/addons/qemu/vtmgmt-20.7.1
mv viptela-vmanage-20.7.1-genericx86-64.qcow2 virtioa.qcow2
4- /opt/qemu/bin/qemu-img create -f qcow2 virtiob.qcow2 100G
5- cd
please assigned 24 GB RAM at least.
Shambhu Kumar
08-15-2024 07:36 AM
Thank you Kumar. I will try it tomorrow I am at work at this time.
08-16-2024 02:01 PM
Hi Sir, i have assigned 24GB of RAM to Vmanage but it is doing the same things, means boot and shutdown but when i reduce it to 4GB it boots but nothing is going on...
