Implement QoS in Cisco SD-WAN through VLAN Interface
dimdim12
I have a question about Implement QoS in Cisco SD-WAN through VLAN Interface, i have Cisco SD-WAN Router ISR C1111-8P on branch office,  it's running fine with communication between another branch office. I want to adding some feature about QoS for limit bandwidth. In my configuration, i using Layer 2 for VLAN interface (switchport mode access).
Is possible to implement QoS in L2 VLAN Interface? Because, i dont find any documentation to discussion that.
I hope any forum member can help me about my problem, Thanks in advance
I haven't worked with ISR1k, but as you mentioned there is no doc for L2QoS. Maybe it still works (but don't think so) if you apply sd-wan access-list on physical interface.
But you should still use policing (limiting) on L3 interface with SD-WAN ACL.
HTH,
