SD-WAN control connection
sanp
My control connection between vmanage and vbond is established without configuring the tunnel interface on vbond device on vpn 0 instance however tunnel interface is configured at vmanage side.
Even if i shutdown the interface of vpn0 on vbond device still control connection is showing up at vbond and vmanage itself.
5 Replies 5
it can't be, share outputs, screens etc.
HTH,
Hi Kanan,
I have attached the screenshots here.
Did you try to clear connections? Maybe it uses previous sockets or you have never configured tunnel on vbond?
HTH,
Yes, I have never configured a tunnel on vbond, also control connection is coming up even I clear the connection. Strange behavior!
Yeap, indeed, it is strange. I'll try in my own lab and give results.
HTH,
