Interface ge0/0 is listed at first one on vEdge
interfacedy
Hi During the configuration for vEdge via device template, the last step is to attach the device template to vEdge. The below is the last step, and we need to do the last edit before the attach. The vEdge has three interface: ge0/0, ge0/1 and ge0/2. Can we say the first IPV4 address is responded to ge0/0 and second is ge0/1 and ..? but sometimes the below first IPV4 Address must not be ge0/0, why? Why the three IPV4 address do not indicate port number in the below? so that we are not sure which one is ge0/0. Thanks.
They are not given in ordered. Just change variable name (right now it is the same for all three - "vpn_if_ipv4_address") for IP address section while creating feature template. For example, "vpn0_if_inet1" "vpn0_if_mpls" "vpn1_if_g0/0/1" etc. You can give any name, it is just variable name which is needed to be filled when you push configuration.
HTH,
HTH,
interfacedy
Thank you very much!
