vManage is not peer to vedge
interfacedy
Hello, The sdwan system has each vbond, vsmart and vmanage. In vEdge, we can see one peer vSmart instead of vmanage as some document mentioned. Is the below result correct? Thanks
2 Accepted Solutions
svemulap@cisco.com
OMP is run between Edge device and vSmart.
OMP is similar to BGP, a routing protocol runs between vSmart and Edge devices.
CCO Design Guide has additional Info.: https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html?dtid=osscdc000283
so many issues in your labs
I suggest and recommend to read Cisco Validated Design guide to understand architecture.
And yes, it is normal. Because OMP is overlay routing protocol which runs between edge routers and vSmart (control plane controller) and between vSmarts (if multiple deployed).
HTH,
svemulap@cisco.com
HTH,
interfacedy
Thank you all!
