Is there a way to modify a variable for several devices in 1 push in?
We have approximately 1k SDWAN edge devices in our SDWAN environment right now. We are looking to add a new vlan to all of the devices and associated IP addresses to the new VLAN.
I am aware of how to download and upload config changes via CSV to a single device, but is there a way to do this to several/all devices in a single push to avoid having to touch every single device and pushing?
I heard back from TAC and will provide the solution if anyone else runs into this.
You need to go under dConfigure and then device templates. Select each template and Change device values and you can download/upload a csv file to modify each device attached to that template and push on a per template basis.
