ISR1100 operating system replacement
maxnpj
I have a few ISR1100-4GLTE-NA models that came with IOS XE as the installed O/S and I don't want to use that right now. I'd rather have the Viptela O/S. I have found plenty of documentation explaining how to put the SDWAN O/S on top of an IOS XE image on a router such as a 4331, but that's not what I want...I want the IOS XE image gone and the Viptela image in its place in this ISR 1100.
Is there some easy way to do this? I'm thinking I can FTP the Viptela O/S to the device, "install-image" and then "activate" and reboot. Is it that easy?
maxnpj
Answered my own question here.....I had to get 20.4.1 on my laptop, then SFTP that to the target vEdge; "install" the software on the vEdge and then "activate" the software on the vEdge; once that was completed and the vEdge was on 20.4.1 I then downgraded the same vEdge to 20.3.4 using the same process...SFTP; install; activate.
The IOS XE image is gone; the Viptela OS is on the device and working fine.
Thanks to me on this one.
BryanHefner2568
You bought a Cisco device. It’s going to run Cisco code. 2 years ago, SDWAN code was different than the IOS XE code, but now it’s all the same. If you want to run a code version that 2 years old, go for it, but no one will be supporting you on that code.
Well...maybe you're right about that, but just so I understand so that I'm not trying to do something that can't be done here:
You're saying that the code is the same? Therefore the CLI commands are the same and the templates are the same? I was unaware of that, so thank you for pointing that out.
You're stating that the Viptela 20.3.4 version is 2 years old? or the 20.6.1 version as well? I thought those were more up to date but thank you for pointing that out. I was unaware of that.
TAC does not support the current version of Viptela code (20.3.4 or 20.6.1)? I was unaware that TAC had stopped supporting that code....thanks for the info.
Not exactly saying you can't do it.  Just that its not a good idea on the router that you have.
You bought a Cisco Router, not a Viptela router.  So you have to run the Cisco Code.  Previously, Cisco has two separate code versions; One for SD-WAN, and one for traditional IOS Routers.  Starting about a year ago, this is just a single unified code version now.  Cisco recommends release 20.3.3.1 (vManage/Controllers) and 17.3.x (Routers).
To use the SD-WAN software, you just convert the router into controller mode for SDWAN.  Then the commands change.  You can still use a lot of the "show" commands for IOS, but now you can also use the 'show sdwan ..." commands.  It also changes configuration mode from 'conf t' to 'config-terminal', and requires a commit before exiting config mode to apply the configuration.
You can still install the 16.12.x code on your router, but from experience, first time you open a TAC case, Cisco is going to have you upgrade.
It is Viptela code, its just integrated fully into IOS now.
maxnpj
