Cisco ISR4221X crash unexpectedly with "Critical process ompd fault on rp_0_0 (rc=139)"
Lee Win Neng
I am using Cisco ISR4221X with SDWAN-image version 17.4.1a in controller-mode and recently saw a crashed on the router with the output below. I had go through the datasheet and bug lists unfortunately I did not found any related bug that mentioned about critical process for ompd.
pvp[19656]: %PMAN-0-PROCFAILCRIT: A critical process ompd has failed (rc 139)
pvp[22984]: %PMAN-5-EXITACTION: Process manager is exiting: Critical process ompd fault on rp_0_0 (rc=139)
Kindly need some assistance to advice that what is the possible cause of this error or any possible new bug?
Thank you for the kind assistance.
Lee Win Neng
Bug ID: CSCvw79936
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvw79936/?rfs=iqvred
To be resolve in version 17.5.1a, 17.6.1a and 17.6.2 onwards
5 Replies 5
Lee Win Neng
Anyone can help me on this ya?
Thank you.
ivances
Hello Lee Win,
Its a bug of this version that Cisco says that will be fixed on future versions.
Kind Regards,
Iván Ces
Appreciate so much for your reply while is there any target version that will be fixed on future versions?
Thank you for your kind assistance and reply.
Hello Lee Win,
Cisco said that it is fixed at 17.4.2.
I would appreciate if you could mark the above message as a solution
Lee Win Neng
Bug ID: CSCvw79936
