NAT and PAT on vEdge
rhyli
I am new to Cisco SD WAN, I do the static NAT and PAT for one of my servers and a PC but it does not work. There is a firewall NAT a public IP to the Edge.
Firewall -------------------------- vEdge  ------------------------------------ LAN
Public IP                       192.168.0.2/24                             192.168.140.0/24
vpn 0
dns 8.8.4.4 primary
dns 8.8.8.8 secondary
interface ge0/0 ip address 192.168.0.100/24
nat
port-forward port-start 3389 port-end 3389 proto tcp private-vpn 0 private-ip-address 192.168.140.2
I try to follow the document to do it but no succeed.
https://sdwan-docs.cisco.com/Product_Documentation/Software_Features/Release_18.3/07Policy_Applications/04Using_a_vEdge_Router_as_a_NAT_Device/Service-Side_NAT_Configuration_Example
ekhabaro
You LAN interface is in service side and most likely in a separate VPN (e.g. 1). VPN 0 in opposite is transport VPN. So I assume you have an error in your configuration. Your private-vpn should be service VPN (e.g. 1..511) where 192.168.140.0/24 subnet resides.
Simon Ko
Seems that what you are missing is one statement.
On service side of vpn, let's say vpn1, add following statement
vpn 1
ip route 0.0.0.0/0 vpn 0
I know this works.
