Need help with EIGRP
MichaelY
I am setting up SD-WAN routers in a lab to prepare for a migration project. I have 2 sites A and B. At both sites A and B I have an SD-WAN router connected to a layer 3 core switch running EIGRP. The core switch is the default gateway for all VLANs at that site. I would like to setup EIGRP on my routers to redistribute EIGRP routes to the other SD-WAN sites. I believe I need to set up the redistribute tab on the EIGRP template.
I read through the template document at this link: https://sdwan-docs.cisco.com/Product_Documentation/vManage_Help/Release_18.4/Security/Revision_19.1_Topics/EIGRP
I am not sure what the Route Policy for OMP is. Can anyone assist?
nriv
The redistribute tab redistributes protocols INTO EIGRP. Theoretically you can create a policy under Configuration --> Policy and reference it in that route-policy area, but I have not tested it.
You say you want to redistribute EIGRP OUT, so that would be EIGRP INTO OMP? That would be under the OMP feature template.
