03-23-2020 12:25 PM
Working to create a policy for a tenant but am unable because that tenants vSmarts are in CLI mode.
When I go to create a template for the vSmart, vSmart is not available as a Device model. This goes for both the tenant/sp view and for CLI/Feature templates.
Ver. 19.2.097
Is this a bug or am I just doing it wrong?
Solved! Go to Solution.
03-23-2020 02:14 PM
Figured it out. The key is to login as the SP. Then browse to the tenant dashboard.
You are unable to do much vSmart maintenance from the SP dashboard or logging in as the tenant.
03-23-2020 02:14 PM
