Not able to add VEDGE-CLOUD in cisco virtual smart account
Yashmit
Hello Champs ,
I need to download serial file for vedges for my lab but while adding VEDGE-CLOUD-DNA , my smart account showing error : This is an export restricted product. Your smart account doesn't have clearance to use this product."
Could you please suggest me from where i got this permission or do i need to create new account ?
Please refer attached snapshot.
helenaferdy
hi, i encountered the same issue. have you found a solution for this?
chand_0073
Facing the same problem, cant even open a support case from SMC portal since dont have an active contract
Anybody able to get a workaround for this problem
You need to first contact your Cisco partner and request them to enable "export controlled features" for you smart licensing account.
HTH,
