On Prem SD WAN controller and DC Edge Router communication
Salauddin
Hello Team,
We have on Prem Controllers are installed in DMZ, for DC SD WAN Edge VPN 0 interface is connected to MPLS CE routers and Service VPN is connected to DC LAN core switch. Can you please confirm if we can enabled Edge routers & controller communication through service VPN ?
inderdeeps
Level 4
Level 4
Hi Salauddin,
So the connectivity from the branches to the DMZ in the DC through the MPLS links ? The WAN connectivity should be from VPN 0 as recommended as service VPN is basically for LAN connectivity. It may possible technically but not recommended i think.
Inderdeep Singh
www.thenetworkdna.com
you can't use service side or VPN512 for control communication. Control communication can only and only happen over VPN0. So, in your case MPLS CE node should route traffic to controllers.
HTH,
Oluyemi
Hi, I'm not sure if you ever got through this problem, but by design controller traffic should come through VPN0 as this is the designated VPN for transport (Global routing table). What works is to have your DC WAN Edge connect via a non-tunnel interface in VPN0 to the segment where you have your controllers, and also have your DC advertise your controller subnet via MPLS to the branch networks. This way both your Edge and remote locations have the controller details via MPLS.
