Path selection for specific traffic through secondary link
ravi310859
I want to select the secondary path instead of Primary path for specific subnet 20.0.10.0/24 for our SDWAN Fabric.
Scenario : From Site A to Site B preferred path for all the traffic is through Primary Link which is reaching on 40.1.1.0/24 which is hosted on AWS cloud.
Requirement : For specific subnet 20.0.10.0/24 only  I want secondary link to be preferred while reaching to the 40.1.1.0/24. Kindly provide a document or configuration example to achieve the same.
I am attaching here a topology for reference.
Thanks & Regards
Ravi
dijix1990
Hiç
are Site A routers connected to both links ? What technology do you use on LAN side, routing protocol or VRRP/HSRP?
Technically, if you configure data policy from service to tunnel that matches 20.0.10.0/24 destination prefix and you set to local TLOC which is based on secondary link. - is the option.
Also, in OMP you may do it bu advertising 20.0.10.0/24 route with higher OMP preference.
If you provide more details about site A LAN design I can give you more detailed answer.
By the way, what is "preference" value in your topology exactly?
HTH,
