Policy to Reset IP NAT Filter
sofobs
Hi all,
I have an issue with a router where I need to reset the Session (clear IP NAT Filter )every 2 or 3 hours depending on the counter field otherwise users will face latency in accessing the Applications
Is there a way to create a policy based on filter-count  or  fib-filter-count to reset the session when the count reaches the boundary set? (temporary Solution for now)
Manual reset result
Before reset :
ip nat interface nat-vpn 0 nat-ifname gre150
 mapping-type     endpoint-independent
 filter-type      address-port-restricted
 filter-count     121453
 fib-filter-count 121491
 ip               xxx.xxx.x.x/30
 number-ip-pools  0
After Reset :
 filter-count     2480
 fib-filter-count 2433
 ip               xxx.xxx.x.x/30
 number-ip-pools  0
  Thank you for your support
ekhabaro
from the top of my head, I would use some external automation tool to perform quick and dirty workaround for such kind of task with help of expect script.
