vBOND not creating dtls connections to cEdge CSR1000v rejecting with BIDNTVRFD (ERR_BID_NOT_VERIFIED)
ovel1
I'm trying to build a lab based on EVE-NG, viptela controllers and CSR1000v images and It looks like i'm unable to overcome this issue.
I'm using my own enterprise root CA. All vManage, Vbond and vSmart are successfully up and running. Tried on different versions, the problem can be recreated on any available controllers and CSR1000v images.
what has been done:
0. I have all 3 controllers up and running, no issues.
1. I created a list of CSRv devices in the cisco PnP portal and downloaded the file list.
2. The list was uploded into vManage.
3. Bootstrap was generated, and uploaded into CSRv and then request platform software sdwan software reset used
4. L3 connectivity was provided and working, tunnels created CSRv was visible in vmanage.
5. The widely described way to use the command "request platform software sdwan vedge_cloud activate chassis-number" did not work. the CSRv simply were not able to communicate to vManage/vBond after that having DISTLOC.
6. I decided to use manual signing the devices certificates. Cert signed, new certificate successfully uploaded on CSRv. Once it's done, the CSRv is never able to make connection to vBond having the error as in the subject
some snippets:
CSRv:
HQ-R1#sh sdwan run
system
system-ip 172.16.0.12
domain-id 1
site-id 1
admin-tech-on-failure
organization-name "OVEL Lab"
vbond 1.1.0.12
ntp peer 1.1.0.1
interface GigabitEthernet1
no shutdown
ip address 1.1.1.2 255.255.255.0
no mop enabled
no mop sysid
negotiation auto
interface Tunnel1
no shutdown
ip unnumbered GigabitEthernet1
tunnel source GigabitEthernet1
tunnel mode sdwan
exit
clock timezone AEST 10 0
sdwan
tunnel-interface
encapsulation ipsec
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
no allow-service snmp
exit
HQ-R1#sh sdwan control local-properties
personality                       vedge
sp-organization-name              OVEL Lab
root-ca-chain-status              Installed
certificate-status                Installed
certificate-validity              Valid
certificate-not-valid-before      Apr 16 14:34:48 2021 GMT
certificate-not-valid-after       Apr 16 14:34:48 2023 GMT
enterprise-cert-status            Not-Applicable
enterprise-cert-validity          Not Applicable
enterprise-cert-not-valid-before  Not Applicable
enterprise-cert-not-valid-after   Not Applicable
dns-name                          1.1.0.12
site-id                           1
domain-id                         1
protocol                          dtls
tls-port                          0
chassis-num/unique-id             CSR-16711BCD-4B91-4A39-E3BD-C63E6A5EC003
serial-num                        100000001D3D436E39E4A99B3300000000001D
token                             Invalid
keygen-interval                   1:00:00:00
retry-interval                    0:00:00:16
no-activity-exp-interval          0:00:00:20
dns-cache-ttl                     0:00:02:00
port-hopped                       TRUE
time-since-last-port-hop          0:00:24:21
embargo-check                     success
number-vbond-peers                1
INDEX   IP                                      PORT
0       1.1.0.12                                12346
number-active-wan-interfaces      1
 NAT TYPE: E -- indicates End-point independent mapping
           A -- indicates Address-port dependent mapping
           N -- indicates Not learned
           Note: Requires minimum two vbonds to learn the NAT type
                         PUBLIC          PUBLIC PRIVATE         PRIVATE                                 PRIVATE        MAX   RESTRICT/           LAST         SPI TIME    NAT  VM
INTERFACE                IPv4            PORT   IPv4            IPv6                                    PORT    VS/VM COLOR                                                   STATE CNTRL CONTROL/     LR/LB  CONNECTION   REMAINING   TYPE CON
        STUN                                              PRF
GigabitEthernet1         1.1.1.2         12386  1.1.1.2         ::                                      12386    0/0  default                                                 up     2      no/yes/no   No/No  0:00:00:00   0:10:42:56  N    5
Root CA is imported
HQ-R1#sh sdwan certificate root-ca-cert | i OVEL
        Issuer: DC=LOCAL, DC=OVEL, CN=OVEL-WINSERVER-CA
        Subject: DC=LOCAL, DC=OVEL, CN=OVEL-WINSERVER-CA
connection-history
PEER     PEER     PEER             SITE        DOMAIN PEER             PRIVATE  PEER             PUBLIC                                   LOCAL      REMOTE     REPEAT
TYPE     PROTOCOL SYSTEM IP        ID          ID     PRIVATE IP       PORT     PUBLIC IP        PORT    LOCAL COLOR      STATE           ERROR      ERROR      COUNT DOWNTIME
vbond    dtls     0.0.0.0          0           0      1.1.0.12         12346    1.1.0.12         12346   default          challenge_resp  RXTRDWN    BIDNTVRFD  38    2021-04-17T02:33:29+1000
obviously, L3 is up and everything is pingable
Vbond log messages:
Apr 17 02:34:20 OVEL-VBOND1 VBOND[10509]: %Viptela-OVEL-VBOND1-vbond_0-6-INFO-1400002: Notification: vbond-reject-vedge-connection severity-level:major host-name:"OVEL-VBOND1" system-ip:1.1.255.12 uuid:"CSR-16711BCD-4B91-4A39-E3BD-C63E6A5EC003" organization-name:"OVEL Lab" sp-organization-name:"OVEL Lab" reason:"ERR_BID_NOT_VERIFIED"
Apr 17 02:34:20 OVEL-VBOND1 confd[992]: netconf id=21 sending notification {http://viptela.com/security}vbond-reject-vedge-connection
Apr 17 02:34:20 OVEL-VBOND1 VBOND[10509]: %Viptela-OVEL-VBOND1-vbond_0-6-INFO-1400002: Notification: control-connection-auth-fail severity-level:major host-name:"OVEL-VBOND1" system-ip:1.1.255.12 personality:vbond peer-type:vedge peer-system-ip::: local-system-ip:1.1.255.12 local-color:default reason:"ERR_BID_NOT_VERIFIED"
Apr 17 02:34:20 OVEL-VBOND1 confd[992]: netconf id=21 sending notification {http://viptela.com/security}control-connection-auth-fail
Valid vEdge:
OVEL-VBOND1# show orchestrator valid-vedges
orchestrator valid-vedges CSR-16711BCD-4B91-4A39-E3BD-C63E6A5EC003
 serial-number                    100000001D3D436E39E4A99B3300000000001D
 validity                         valid
 org                              "OVEL Lab"
 hardware-installed-serial-number N/A
 subject-serial-number            CSR-16711BC
not sure where subject-serial-number is coming from. But I also tried to create vEdge manually on vBond without the subject-serial-number, it didn't help
OVEL-VBOND1# show orchestrator connections
        PEER                      PEER
         PEER     PEER     PEER             SITE        DOMAIN      PEER             PRIVATE  PEER             PUBLIC                                   ORGANIZATION
INSTANCE TYPE     PROTOCOL SYSTEM IP        ID          ID          PRIVATE IP       PORT     PUBLIC IP        PORT    REMOTE COLOR     STATE           NAME                    UPTIME
0        vsmart   dtls     1.1.255.13       255         1           1.1.0.13         12346    1.1.0.13         12346   default          up              OVEL Lab                0:00:26:17
0        vsmart   dtls     1.1.255.13       255         1           1.1.0.13         12446    1.1.0.13         12446   default          up              OVEL Lab                0:00:26:17
0        vmanage  dtls     1.1.255.11       255         0           1.1.0.11         12346    1.1.0.11         12346   default          up              OVEL Lab                0:00:26:19
0        vmanage  dtls     1.1.255.11       255         0           1.1.0.11         12446    1.1.0.11         12446   default          up              OVEL Lab                0:00:26:21
0        vmanage  dtls     1.1.255.11       255         0           1.1.0.11         12546    1.1.0.11         12546   default          up              OVEL Lab                0:00:26:21
0        vmanage  dtls     1.1.255.11       255         0           1.1.0.11         12646    1.1.0.11         12646   default          up              OVEL Lab                0:00:26:21
connection-history
        PEER     PEER             PEER
         PEER     PEER     PEER             SITE        DOMAIN      PEER             PRIVATE  PEER             PUBLIC                                                     REPEAT
INSTANCE TYPE     PROTOCOL SYSTEM IP        ID          ID          PRIVATE IP       PORT     PUBLIC IP        PORT    REMOTE COLOR     STATE             LOCAL/REMOTE    COUNT DOWNTIME
0        unknown  dtls     -                0           0           ::               0        1.1.1.2          12386   default          tear_down        BIDNTVRFD/NOERR     45    2021-04-17T02:37:17+1000
vBond config:
OVEL-VBOND1# sh run
system
 host-name               OVEL-VBOND1
 system-ip               1.1.255.12
 site-id                 255
 no route-consistency-check
 no vrrp-advt-with-phymac
 clock timezone Australia/Brisbane
 vbond 1.1.0.12 local
 aaa
  auth-order local radius tacacs
  usergroup basic
   task system read write
   task interface read write
  usergroup netadmin
  usergroup operator
   task system read
   task interface read
   task policy read
   task routing read
   task security read
  usergroup tenantadmin
  user admin
   password $6$54082b12c893a22c$x.4TxtWCjpCqKZV8TYSbC6.5P/G8pST1LxlBK/6tBGkC9jk0rlyF5StAukHx8OmX4x/zV.b/Ekb32cg5kGezI0
  user ciscotacro
   description CiscoTACReadOnly
   group       operator
   status      enabled
  user ciscotacrw
   description CiscoTACReadWrite
   group       netadmin
   status      enabled
 logging
  disk
   enable
 ntp
  parent
   no enable
   stratum 5
  exit
  server 1.1.0.1
   version 4
   prefer
  exit
 support
  zbfw-tcp-finwait-time 30
  zbfw-tcp-idle-time    3600
  zbfw-tcp-synwait-time 30
  zbfw-udp-idle-time    30
omp
 no shutdown
 graceful-restart
 advertise connected
 advertise static
security
 ipsec
  authentication-type ah-sha1-hmac sha1-hmac
vpn 0
 dns 8.8.8.8 primary
 interface ge0/0
  ip address 1.1.0.12/24
  ipv6 dhcp-client
  tunnel-interface
   encapsulation ipsec
   allow-service all
   allow-service dhcp
   allow-service dns
   allow-service icmp
   allow-service https
  no shutdown
 ip route 0.0.0.0/0 1.1.0.1
vpn 512
 interface eth0
  ip dhcp-client
  ipv6 dhcp-client
  shutdown
root cert is installed:
OVEL-VBOND1# show certificate root-ca-cert | i OVEL
OVEL-VBOND1#
I also tried to play with invalid/staging/valid in vmanage gui. after moving the CSRv to invalid, vmanage is no longer able to get CSRv details (because it cant make the connection to vBond). So this ste didn't help
Thank you for your help! Spent 3 days, tried everything. looks like something wrong with vBond or i'm missing somethign crucial.
ovel1
After a week of various attempts I found the solution. Guys, make sure ALL your devices have good NTP synchronisation! This was the key!
I have put eventually 4 NTP servers into all controllers and edges configs and it started working after that.
And yes, I can prove now that it's working ok in EVE environment.
p.s. and also not sure this helps but in your EVE environment try to set your CSRv network interfaces as "virtio-net-pci" instead of vmxnet3.
Julio Marquez
Assuming you are not running incompatible versions of vBond/vManage and CSR1000v, check if you are not hitting https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp75927
ovel1
