12-03-2023 07:31 AM
I'm interested, is it possible to make qos rules for some branches which have different channel bandwith?
For example,
5 branches with two isp's (30mbit per isp)
3 branches with two isp's (50mbit per isp)
3 branches with two isp's (100mbit per isp)
I want to implement qos for branches (for traffic from branches to dc)
Is it possible to use qos which will be depend from bandwith isp? Maybe some examples?
12-03-2023 08:05 AM - edited 12-03-2023 08:06 AM
Or one question, maybe anybody know for what we can enable feature "cloud qos" on the local policy? Is it only for cloud edge?
12-03-2023 08:07 AM
Usually, yes.
Unsure what you mean by "depend" on ISP's bandwidth.
As for examples, as QoS features can vary much between platforms, what specific platforms do you have in mind?
12-03-2023 08:28 AM
QoS should devide bandwith in terms of isp channel as example (on the velocloud) I set bandwith on the uplink 30mbps and qos sees bandwith and devide it between different classes for example class 0=50%=15mbps / class 1=50%=15mbps, isp increase channel to 60mbps and I chande bandwith to 60mbps on the uplink interface and qos automatically adjusted to new bandwith
As edges I use isr4000/isr1000/isr8300/c8000v
12-03-2023 09:33 AM
If you use percentage based statements, proportions are maintained.
However, unless port is physically running at ISP bandwidth, for egress QoS to be effective, you'll need to have a parent policy with a shaper for the ISP bandwidth allocations, and, I don't recall, a way to have the shaper "know/use" actual ISP bandwidth.
12-03-2023 09:40 AM - edited 12-03-2023 09:31 PM
Check below
MHM
12-03-2023 07:11 PM
So, You mean for every transport I need to use shaper policy and after devide trafic via QoS police and percentage?
12-03-2023 09:30 PM
There are two approaches' I think using percentage meanly use for class based. Here you want to shaped all traffic.
MHM
12-03-2023 10:06 PM
I know the difference, I use it a lot in my legacy environmet, I asked about SD-WAN because it has very weird instructions and examples. Veloclud (VMWare sdwan) has very flexible QoS implementing and I would like to know if the cisco sdwan has the similar behaviour - For example If I set the bandwidth on the interfaces, like this
interface Vlan100
description -E- ### Internet channel
bandwidth 40000and apply QoS policy on the velocloud so QoS grab bandwidth to use it for policing.
From documentation for Cisco SD-WAN I understood that before I need to set shaper bandwidth and after aplly QoS policy that will depend on shaper bandwidth
12-04-2023 02:07 AM
Oops, BTW, I missed noticing your OP's SD-WAN tags and the forum your question is within. My replies were intended for a non SD-WAN environment. Unfortunately, I'm unaware of what SD-WAN supports vis-a-vis QoS.
12-04-2023 02:20 AM
BTW, in your first reference, it's unclear what the shaper uses for its percentage basis, i.e. physical interface bandwidth or interface bandwidth statement.
Ideally it would allow bandwidth statement to override physical interface statement but from a maintenance perspective you would still need to maintain the interface bandwidth statement.
Cisco does have one auto bandwidth shaper for (some) DMVPN. Possibly Cisco provides a similar feature for SD-WAN.
12-04-2023 02:53 AM
I mean interface bandwidth statement
interface Vlan100
bandwidth 40000
12-05-2023 02:58 PM
configure shaper under physical transport interface.
And you also may have QoS Map which will work based on shaper:
Example in CLI will be:
policy-map QoS_MAP > QoS Map created in local data policy
class Queue0
priority level 1
police rate percent 30
class class-default
bandwidth remaining ratio 70
random-detect
policy-map shape_GigabitEthernet0/0/1
class class-default
shape average 30000000 > shaper value (manually typed)
service-policy QoS_MAP > QoS Map name (references QoS_Map created above in local policy)
12-04-2023 02:58 AM
@Joseph W. Doherty The sdwan is another story' there is two service and transport' so we need check where we apply qos under vpn0 or other.
@dijix1990 I will check and update you.
MHM
