SIG Zscaler issue
Mohamed baraka
for SIG Zscaler routing configuration, there are both static and policy ways of forwarding traffic up the tunnels,
1- Is SIG configuration in the policy in anyway affect the LAN protocols ?
2- Is applying the SIG routing as a static and policy ways at the same time is causing any issues ?
SIG sequance in the policy:
    sequence 9
     match
      destination-ip 0.0.0.0/0
     action accept
      sig
SIG route:
ip sdwan route vrf 1 0.0.0.0/0 service sig
svemulap@cisco.com
For your 1st question:
No. SIG Configuration in the policy affects to only what is in the policy.
SIG is applied to the data traffic. Not to the control traffic.
For your 2nd question:
Doing it via data-policy will take precedence. (aka via data policy)
So, whatever is configured for in data-policy, the redirect will happen accordingly.
In the example provided, seq 9 and static are doing the same thing.. which is matching the default route (0/0)
Typically you have a data-policy to match a specific traffic.
