Question about SDWAN Tracker
kay.kang
Hi specialists,
I am trying to find the best practice for the SDWAN tracker setup having two Internet links.
The site have two vEdges and each each will have Internet link and interconnecting by TLOC Extension.
And, each vEdge will have 2 GRE tunnels to Zscaler Service Edge for cloud security service.
We're using the GRE tunnel for default route for any VPN1(service) traffic pointing to GRE1 and GRE2 interface.
And as the secondary default route, we're adding default route with higher AD poiting to TLOC Extension interface.
For LAN side redundancy, we're using VRRP.
And for Internet link failover with Tracker, I put the Internet next hop IP as the tracking end point IP.
So in that case, I guess the primary vEdge will remove the default route from the routing table and the subsequent default route with AD 250 will be on the routing table.
And traffic will be transferred to the backup vEdge over TLOC Extension link.
The design is based on theory and not sure if this is the best practive for the redundancy and tracker design.
Can you please give me any advise me if there is any problem or better idea about this?
Following is configuration example and drawing.
>> vEdge_1 setup <<
ZS GRE 1
GRE Source: ge0/0
GRE Destination: 1.1.1.1
ZS GRE 1
GRE Source: ge0/0
GRE Destination: 1.1.1.2
vpn1
ip gre-route 0.0.0.0/0 vpn 0 interface gre1 gre2
Ip route 0.0.0.0/0 vpn 0 interface ge0/1.2 250
Vpn0
ip route 0.0.0.0/0 2.2.1.1
ip route 0.0.0.0/0 10.1.1.2 250
Tracker1
Track endpoint ip: 2.2.1.1
>> vEdge_2 setup <<
ZS GRE 1
GRE Source: ge0/0
ZS GRE 1
GRE Source: ge0/0
vpn1
Ip route 0.0.0.0/0 vpn 0 interface ge0/1.1 250
Vpn0
ip route 0.0.0.0/0 10.1.2.1 250
Tracker1
Tracking endpoint ip: 2.2.2.1
Seems pretty good. Didn´t see anything I could change. It is a lab or real network? Did you implemented yet?
Not yet implemented.
Try to implement as that plan with Tacker.
Just found only tracker endpoint IP where is able to respond HTTP(tracker packet) can be used.
So that means I can't use the Internet next hop gateway as the tracker endpoint because it's normally just router's IP.
Will need to put any IP or DNS name where is able to respond HTTP.
