SD-WAN PnP offline deployment
hicor53095
HI
i have couple of ISR 4k i want to attach to vmange
my transport only MPLS with no internet
is there any way to have the PnP enabled or it must be from Cisco portal and using internet
thanks
5 Replies 5
balaji.bandi
where is vManage ? inside your network or Cloud ?
check onboarding :
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/SDWAN/sdwan-wan-edge-onboarding-deploy-guide-2020nov.pdf
BB
it will inside the network
Then you need to make own DNS records for the PNP work, internally for the devcie to recognise Local SD-WAN deployment.
BB
Hi Balaji
thanks for your reply,
do you have any document or guide for that.
like where to do the DHCP since MPLS is 3rd party
