RE: SDWAN Design Queston
faisal.memon
Can we configure DC site in SD-WAN deployment with 3 different transport from same service provider on pair of router?
Two routers having 3 transport connection each (MPLS,Internet and Metro Ethernet).
Faisal
Simon Ko
This might help you with finding answer.
As long as there is a path from vEdge via transport to vmanager server/vbond server, it does not care.
For example, our DC has three transports terminating in dc.
MPLS, MetroE and Private VPN all terminate in DC, comes out of same exit point ,and talks to vManage.
It sees 3 transports and 3 control connections.
I think NAT is built into this, so as long as there is a path, it works.
Hi Simon,
All your three transport are connected to one router?
