Restric default-route to be re-distributed OMP
jeded
I have a cEdge router with a couple static routes that are re-distrubuted to the rest of the network
Also I have a default static route "ip route vrf 1 0.0.0.0 0.0.0.0 10.xx.xx.xx" and i do not want this route to be re-distributed.
How can i achieve this?
Br,
Jean
bahkobg85
Hi Jean,
IMO, you can apply an inbound centralized control policy to this site, filter out this exact vroute and accept all others (set the default action to accept). This will prevent the route from entering vSmart's VPN1 route table and, consequently, will not be advertised out to other sites/edge routers.
HTH, Ivan
Another option is to stop advertising static routes into OMP and just advertise the network that you required leaving the default-route out.
