Running config on Vmanage is not the same as running config on Vedge
Sam Peck
Hello all,
I have a Viptela Vedge 1000. When I select the device on Vmanage , I can see my default route in the running config; however, when I SSH directly to the device, I do not see the default route in the running config. The default route is presented in the routing table though. Anyone knows what the reason is?
share show run vpn [X] - X is respective VPN where default is expected and also sh ip route vpn X
HTH,
I attached the config. I can see the following command in Vmanage under vpn 0 but they are missing in the Vedge running config
ip route 0.0.0.0/0 1.1.1.1
ip route 0.0.0.0/0 95.50.23.185
balaji.bandi
is the template managed by vManange -
show sdwan running-config
show run all
show ip route
Note : what version of vManage and vEdge ?
BB
I can not share all the config.
I attached the config partially. I can see the following command in Vmanage under vpn 0 but they are missing in the Vedge running config
Vedge version :20.3.5.1 and it is managed by VManage
